Community Member
Disable touch tones?
I have a customer that want to disable touch tones on some of their c7912 phones on their CUCM 7.1.3.
They don't want to disable DTMF, they just don't want to hear the tones when they press the buttons on the phone.
I've tried to look for a solution on the web, but no luck.
Everyone's tags (3)
Is it for 7912 or 7921 phone model ?
If it's for 7921, procedure is documented on page 79 of
Couldnt find similar procedure for 7912 though.
Pls rate helpful posts by clicking on stars below the post !!
Community Member
It's for the 7912, not 7921.
hi Lasse,
On a  7912 there is no way to disable the playing of DTMF tones.
When you are on the handset/headset, the phones (whether the originator
or destination of the tones) will always play the true DTMF tones. When
on speaker, the phones will always play a default tone for both security
reasons (so no one can listen to the tones played) and also for a
performance reason (to avoid bleed through that may result in double
tones on an IVR).
You could disable out-of-band DTMF (for IOS gateways at least), which
simply forces the tone to be sent in-band instead. So the tone is still
sent and heard, it just runs the risk of being distorted since the tone
is sent as part of the media stream, as opposed to being recreated
exactly at the far end.
Hope this helps!
Community Member
Hi, thank you for your reply.
It was as I "feared" =)
Do you know if it is possible to disable the tones for all phones instead?
If it is possible then that perticular phone's End User Guide or Admin Guide will have a procedure documented for that.
Pls rate helpful posts by clicking on the stars below the post !!
