Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Disable user personalization on Unity Connection
Hi all, I'm searching a way to disable (and keep the default parameter) the first personalization of voicemail prompted to the user the first time that they access it.
I don't want that my users hear that menu and set some default param like greeting and pin.
Anyone have see this option? I can't find it and I don't know if exist.
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Uncheck "Set for Self-enrollment at Next Sign-In" from the user main page or template.
HTH,
Chris
1 REPLY
HTH,
Chris
158
