08-17-2007 01:23 AM - edited 03-14-2019 11:07 PM
Hi all,
I have a receptionist who would like to know if it is possible for her to prevent calls going through to there voice mail if she needs someone to pick the phone up in an emergency.
Im not sure if there is functionality to do this in Callmanager. Does anyone know if this is possible?
Kev
08-23-2007 06:09 AM
Try disable forward to VM "disable feature
08-23-2007 06:35 AM
Is this feature available in 4.1?
I dont seem to be able to see it.
Kev
08-23-2007 06:51 AM
To disable Forward to VM, you can set the VoiceMail Profile for the Directory Number to "None". Also, please be aware that this will completely disable VM for the user and cannot be done on a call by call basis. Another thing you will have to play with is increase Ring No Answer settings. The default should be 16 (Which would be 4 Rings - 4 seconds for 1 Ring). So increase the Ring No Answer timer as well on the phone.
Hope this helps
08-24-2007 01:40 AM
Is it possible to achieve this in IPCC?
Ive investigated it and it doesnt look like it is.
Thanks for your help.
Cheers
Kev
