disable voice ports in VG224(sccp)
Hi, I have  a problem in the CUCM version 6.
The  problem is that the cpu is very high, a TAC engineer tells me it's because I  have many ports on the VG224s (50 devices)  without giving an extension, the engineer  recommended that I disable unused ports.
As I do to disable this ports   of VGs?
thanks
Julio
1 ACCEPTED SOLUTION
Re: disable voice ports in VG224(sccp)
Yes, shutting down the port will prevent it from
attempting to register with the CUCM. You
can also issue shutdown on the pots dialpeers
corresponding to those ports not in use and
service stcapp.
Infact should not have those dialpeers to begin
with.
To disable ports on Vg224:
login and get into the priv exec mode
configure the voice-port you wish to disable
perform a shut on that port
thank you .
if  I put a port in shut, the port stopped trying to register on the ccm?
thanks again
Julio
service stcapp.
with.
1505
