Disable web access on softphones
I don't want people to go to the ip address of softphones and get certian info. Can this be done? I treid to crate a new device profile for it and still don't see the options to disable it
Re: Disable web access on softphones
maybe this helps
CIPC interferes and conflicts with the web server installed on the PC
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K54967101
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
I tried that but I can still access it. Thanks for the reply.
VIP Super Bronze
you can disable the settings access by going to the phone page in callmanager and scroll down to Product Specific Configuration Layout and then under the settings access, you can choose diable. This will block access to see any of the callmanager ip address and config etc
For the directories, you can easily type in a wrong directory in the directory url on the phone, wo when the directory button is pressed, the user cant see the corporate directory.
eh in the directory url, type in http://no access/
pls rate useful posts
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
128
