Community Member
Disabling PC voice VLAN access
If I disable PC voice VLAN access, what will I lose in the way of functionality with regard to CTI/ JTapi apps like web dialer, or IPMA, etc. -apps that interact with the phone? -chris
Community Member
Re: Disabling PC voice VLAN access
you wont lose any functionality, except the possibility to put an ATA behind a Phone for example
Community Member
thank you.
Community Member
Forgot to tell you that you'll have problem with disabling PC Voice VLAN access when you use VMPS (not so frequent I know)
1254
