You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Disabling the PC Voice VLAN Access Setting
Hello
we need to Disable the PC Voice VLAN Access Setting in the phone configuration of a callmanager 3.3(4). The problem is we have more than 3500 phones attached an don't want to make that task phone by phone. Has anyone an idea on how to do a batch or is there a global parameter to Disable the PC Voice VLAN Access Setting?
Thanks for your help
Reto
  • IP Telephony
Re: Disabling the PC Voice VLAN Access Setting
you can use BAT
Thanks for your help, we just found it. But can set this as default? That means, if I connect a new phone the value is set to disabled?
Reto
if you add a phone manually then you can set it to disabled. But if you BAT phones on to your system you can set up a template to use which you pre set voice vlan access to disable.
468
