Disabling Web Access CM 4.1
Aaron Dhiman
Level 2
Level 2
I have looked for a way to disable Web Access to a lot of phones with CM 4.1, but can't seem to find a way to do it with Device Pool, Enterprise Params, Service Params, or BAT.
Any way to do it?
This can be accomplished with the BAT tool. I just did it in my lab. You select update phones, using a query, then a model type (i did 7940), and an option on the bottom right of step two is Web Access.
Check the box, and set the drop down to the desired value.
keep in mind that this will do ALL phones of that model, and could be VERY system intensive.
I'm using CCM 4.1(3) with BAT 5.1(4a)
hope that helps.
Rajesh Revuru
Level 4
Level 4
I am not really sure, but can this be acheived with Mutli Level Administration (MLA)?
hope that helps.
That looks like the ticket. Thx.
