Disabling Wi-Fi and BT in the 99xx series
Hi All, what would be the best way to disable the Wi-Fi and BT capabilities in the 99xx phones. My customer would like to make sure they cannot be activated in any way. Thx, Gil
1 REPLY
Re: Disabling Wi-Fi and BT in the 99xx series
Not sure about BT but just the fact you plug a cable to any of the ethernet ports of the phone disables wi-fi.
For wi-fi to work the only cable you need is the one from the power cube.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
245
