Disaster recovery best practice...
All - we are about to install a new UC on UCS solution.   UCS220M3 server with CUCM 9X, CUBAC BE, and Unity Cxn 9X.   I am trying to discern the best way to ensure routine system backup.
Backup at the ESXI host level (or through other facilities typically offered in VMware environment) appears to not be supported.    We are a single host server.     Thus it seems the preferred method is through per application services (DARS for CUCM..)  what about Unity Connection/CUBAC?
Can anyone direct me to a best practice?
1 REPLY
What's officially supported is here:
Unified Communications VMware Requirements
You use DRS for CUCM and CUC
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
141
