Disaster Recovery Solutions CUCM 8x-9x
lordshawn
SO now DRS documentation says this:
For information on using GlobalSCAPE with supported Cisco Unified Communications versions, refer
to the following URL:
http://www.globalscape.com/gsftps/cisco.aspx
Cisco uses the following servers for internal testing. You may use one of the servers, but you must
contact the vendor for support:
Titan (refer to http://www.titanftp.com/
Cisco does not support using the SFTP product freeFTDP. This is because of the 1 GB file size limit on
this SFTP product.
Cygwin (refer to http://www.cygwin.com/
Open SSH (refer to http://sshwindows.sourceforge.net/
So im using FreeFTPD now and it still works? Is there a reason why its not supported now? Is there any free or low cost solutions?
Rob Huffman
Hi Shawn,
This reference to "FreeFTPD" really came from the Unity Connection side of the house originally
and is due to the file size support. Have a look at the Cisco bug listed by Martin in this thread;
https://supportforums.cisco.com/message/3252273?referring_site=bss&channel=bdp#3252273
Cheers!
Rob
"Why do the best things always disappear "
- The Band
