11-22-2011 05:11 AM - edited 03-16-2019 08:10 AM
Hi !
We are facing an issue where even after the disaster recovery process has been completed and the completion shows 100% .
But the history shows errors all the way down as the error message , even after the disaster recovery has been completed.
ccm version : 7.1.3
11-22-2011 01:28 PM
What do the log files show for DRF? If everything fails then it most likely couldn't write to the SFTP destination.
What SFTP server software are you using? As a test, are you able to log into it and write/delete files using WinSCP?
11-23-2011 02:06 AM
Hi Jon,
Thanks for the response.
Well the all the components are showing success hence the first query is checked .
I kindly wanted to know how can we delete teh files using WinSCP , as it is a linux box and honestly i have not used WinSCP.
Can you kindly help on that part.
