disaster recovery system status shows error , backup is completed
Hi !
We are facing an issue where even after the disaster recovery process has been completed and the completion shows 100% .
But the history shows errors all the way down as the error message , even after the disaster recovery has been completed.
ccm version : 7.1.3
VIP Super Bronze
What do the log files show for DRF? If everything fails then it most likely couldn't write to the SFTP destination.
What SFTP server software are you using? As a test, are you able to log into it and write/delete files using WinSCP?
Please remember to rate helpful responses and identify helpful or
Hi Jon,
Thanks for the response.
Well the all the components are showing success hence the first query is checked .
I kindly wanted to know how can we delete teh files using WinSCP , as it is a linux box and honestly i have not used WinSCP.
Can you kindly help on that part.
454
