07-22-2010 02:40 PM - edited 03-15-2019 11:52 PM
Hi, guys and gals.
Does anyone know what a Disconnect Cause=33 means?
I am receiving this on calls placed to the PSTN from a 2851 gateway passing through a Siemens PBX? I don´t see that code tabulated in Cisco´s voice documentation. My calls establish themselves, but get cut at random intervals.
Doing a Q931 debug returns
Jul 22 21:26:47.000: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xC77A
Cause i = 0x80A181 - Unknown cause value
I am assuming the code is generated by Siemens.
Ariel
Solved! Go to Solution.
07-28-2010 12:26 PM
You are correct the far-end is sending the disconnect and not providing a reason.
Were you a part of this call? It looks like the call was up for some time before it got dropped but you'll have to do some debugging on the PBX to see the real reason the call was ended.
-ryan
07-27-2010 07:07 AM
I'd guess that is them responding to a cause that was sent outbound to the Siemens. Can you post the full debug (with edited numbers for privacy of course)?
07-28-2010 12:12 PM
This is the Debug:
Jul 22 21:25:03.525: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x4778 callID = 0xFDB7 switch = primary-qsig interface = User 0xC778 }
Jul 22 21:25:03.525: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x4778
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839E
Exclusive, Channel 30
Calling Party Number i = 0x0081, '12XXX'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '0155017XXXX'
Jul 22 21:25:03.717: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xC778
Jul 22 21:25:06.905: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0xC778
Jul 22 21:25:06.921: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0xC778
Jul 22 21:25:06.949: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0xC778
Jul 22 21:25:14.754: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8 callref = 0xC778
Jul 22 21:25:14.754: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x4778
Jul 22 21:26:46.972: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xC778
Jul 22 21:26:46.972: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x4778
Jul 22 21:26:47.092: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xC778
Cause i = 0x8090 - Normal call clearing
As I see, the Disconnect comes from the Siemens Side
Ariel
07-28-2010 12:26 PM
-ryan
07-28-2010 12:44 PM
Thanks, Ryan!
That´s all I needed to confirm. The PBX is managed by another provider, I already passed the request, but was needing to confirm my suspicions.
Ariel.
