Disconnect Cause = 47 --- Q931 Debug --- Issue
Hello everybody.
Please help me with this.
Call from:
CM 6 ----> PBX Siemmens
When i call from "3001" to "5598" I receive "disconnect cause 47" with debug voip ccapi inout.
I try many thing how is possible with MTP, TXC and CFB (with or without RSVP)
On CCM Administration, Gateway have MTP on.
This is the GW configuration.
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
supplementary-service h450.12
fax protocol t38 nse force ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
  h225 timeout t302 2
  h225 timeout setup 3
modem passthrough nse codec g711ulaw
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
codec preference 3 g711alaw
voice class h323 1
h225 timeout tcp establish 3
controller E1 0/1/0
pri-group timeslots 1-31
interface GigabitEthernet0/0.100
description ## TELEFONIA ##
encapsulation dot1Q 100
ip address 10.73.4.1 255.255.252.0
zone-member security LAN
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.73.4.1
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
no cdp enable
ccm-manager sccp local GigabitEthernet0/0.100
sccp ccm 10.73.4.3 identifier 1 version 5.0.1
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0.100
associate ccm 1 priority 1
associate profile 1 register TXC_CAREMBAR
associate profile 2 register RSVP_CAREMBAR
associate profile 3 register CFB_CAREMBAR
switchover method immediate
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
rsvp
maximum sessions 4
associate application SCCP
dspfarm profile 3 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
dspfarm profile 2 mtp
codec pass-through
codec g711ulaw
rsvp
maximum sessions software 100
dial-peer voice 5598 pots
destination-pattern 5598
port 0/1/0:15
dial-peer voice 5500 pots
incoming called-number .
direct-inward-dial
port 0/1/0:15
dial-peer voice 1000 voip
description ## A CALL MANAGER ##
destination-pattern ....
voice-class codec 1
voice-class h323 1
session target ipv4:10.73.4.3
dtmf-relay h245-alphanumeric
fax rate disable
no vad
DEBUG ISDN Q931 !!! Try to understand why called number isnt appear.
Apr 26 14:52:24 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 3001
Apr 26 14:52:24 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num
Apr 26 14:52:24 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00ED
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x0081, '3001'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80
Apr 26 14:52:28 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00ED
        Sending Complete
                Standard = CCITT
Apr 26 14:52:32 UTC: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x00ED
        Cause i = 0x80E6 - Recovery on timer expiry
Apr 26 14:52:32 UTC: ISDN Se0/1/0:15 **ERROR**: CCPCC_CallOrigination: SETUP timed-out (2nd T303) to NETWORK.  The SETUP failed.
Apr 26 14:52:32 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 3001
Apr 26 14:52:32 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num
Apr 26 14:52:32 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00EE
        Sending Complete
                Standard = CCITT
Apr 26 14:52:36 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00EE
        Sending Complete
                Standard = CCITT
Apr 26 14:52:40 UTC: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x00EE
Apr 26 14:52:40 UTC: ISDN Se0/1/0:15 **ERROR**: CCPCC_CallOrigination: SETUP timed-out (2nd T303) to NETWORK.  The SETUP failed.
Apr 26 14:52:40 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 3001
Apr 26 14:52:40 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num
Apr 26 14:52:40 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00EF
        Sending Complete
                Standard = CCITT
Apr 26 14:52:44 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00EF
        Sending Complete
                Standard = CCITT
Apr 26 14:52:45 UTC: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x00EF
        Cause i = 0x80AF - Resource unavailable, unspecified
Apr 26 14:53:15 UTC: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x00EF
Apr 26 14:53:19 UTC: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x00EF
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
PBX never replies messages from router.
Try setting router isdn network-side.
That is normal. On pots dial-peers you need to configure 'forward-digits all' to prevent the digitsin destianation-patern to be absorbed.
Hi Pablo...
Thanks for your answer.
Youre right... now the number appear but the cause code is still the same.
SEE BOLD
Apr 26 15:24:05 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is        0x0 0x0, Calling num 3001
Apr 26 15:24:05 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is        0x0 0x0, Called num 5598
Apr 26 15:24:05 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00F3
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA9839E
                Exclusive, Channel 30
        Called Party Number i = 0x80, '5598'
Apr 26 15:24:09 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00F3
        Sending Complete
                Standard = CCITT
Apr 26 15:24:13 UTC: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =        0x00F3
Apr 26 15:24:13 UTC: ISDN Se0/1/0:15 **ERROR**: CCPCC_CallOrigination: SETUP tim        ed-out (2nd T303) to NETWORK.  The SETUP failed.
Apr 26 15:24:13 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is        0x0 0x0, Calling num 3001
Apr 26 15:24:13 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is        0x0 0x0, Called num 5598
Apr 26 15:24:13 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00F4
        Sending Complete
                Standard = CCITT
Apr 26 15:24:16 UTC: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x00F        2
Apr 26 15:24:17 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00F4
        Sending Complete
                Standard = CCITT
Apr 26 15:24:20 UTC: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x00F        2
Apr 26 15:24:21 UTC: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =        0x00F4
Apr 26 15:24:21 UTC: ISDN Se0/1/0:15 **ERROR**: CCPCC_CallOrigination: SETUP tim        ed-out (2nd T303) to NETWORK.  The SETUP failed.
Apr 26 15:24:21 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is        0x0 0x0, Calling num 3001
Apr 26 15:24:21 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is        0x0 0x0, Called num 5598
Apr 26 15:24:21 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00F5
        Sending Complete
                Standard = CCITT
Apr 26 15:24:25 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00F5
        Sending Complete
                Standard = CCITT
Apr 26 15:24:26 UTC: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x        00F5
arda#
Like Paulo, mentioned there is no call proceeding message from PBX at all, can you check with them what they didn't like in your setup ? Is it the plan/type ? If they can pinpoint, why they didnt respond then it would be much easier to isolate the issue ?
If you have  working scenario with the pbx, then you stare n compare the debugs and configuration.
Murali
Thanks for your answer Marmugam... im talking now with Siemmens's guy.
I keep you in contact.
Thanks again.
Thanks Paolo,
Now im thinking in issue on Siemmens side...
I put isdn protocol emulate network on serial 0/1/0:15... now i receive this.
Apr 26 15:41:41 UTC: ISDN Se0/1/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from        L2BAD FRAME()BAD FRAME()BAD FRAME()BAD FRAME()BAD FRAME()
Apr 26 15:41:50 UTC: ISDN Se0/1/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from        L2BAD FRAME()BAD FRAME()BAD FRAME()BAD FRAME()
Apr 26 15:41:59 UTC: ISDN Se0/1/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from        L2BAD FRAME()BAD FRAME()BAD FRAME()BAD FRAME()
Apr 26 15:42:08 UTC: ISDN Se0/1/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from        L2BAD FRAME()BAD FRAME()BAD FRAME()BAD FRAME()
Apr 26 15:42:13 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is        0x0 0x0, Calling num 3001
Apr 26 15:42:13 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is        0x0 0x0, Called num 5598BAD FRAME()
Apr 26 15:42:17 UTC: ISDN Se0/1/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from        L2
Apr 26 15:42:17 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is        0x0 0x0, Calling num 3001
Apr 26 15:42:17 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is        0x0 0x0, Called num 5598BAD FRAME()BAD FRAME()BAD FRAME()BAD FRAME()BAD FRAME()        BAD FRAME()
Apr 26 15:42:26 UTC: ISDN Se0/1/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from        L2
Apr 26 15:42:26 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is        0x0 0x0, Calling num 3001
Apr 26 15:42:27 UTC: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is        0x0 0x0, Called num 5598BAD FRAME()BAD FRAME()BAD FRAME()BAD FRAME()BAD FRAME()
Apr 26 15:42:35 UTC: ISDN Se0/1/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from
Then PBX is network side, but doen't want to talk to router. Check with their technicians.
6903
