Community Member
Disconnect mobile calls after 2 minutes
i have a request from a client who needs that calls going to mobile phone gets disconnected after two minutes.
they have CCM 4.13 and possible to uprgade to find a solution.
They have FXO for mobile lines
they have IPCC express 3.5
if also a third party is needed we can go for it.
Good day
1 REPLY
Green
Re: Disconnect mobile calls after 2 minutes
With CCM standalone you cannot configure that...but if you create an script that first answer the call, then you enter the mobile phone yes you can disconnect after some timers expires...
134
