Disconnect PRI-PSTN: 0x80A9 - Temporary failure
hi,
When a place a call from IPPhone to another IPPhone but to the DDI, the Gw drops the call, traces shows "Cause i = 0x80A9 - Temporary failure" and if i repeat the call after few seconds runs properly.
I have make debug isdn q921 to to verify layer 2 events for the isdn, and
debug mgcp errors
debug mgcp packet debug mgcp errors
debug mgcp packet
but I can not see where is the problem because MGCP is correctly configured and other calls go ahead, it looks like only a numeration range, here is traces from Gw
Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839E
                Exclusive, Channel 30
        Calling Party Number i = 0x0181, '9158X XXXX'  (i have modified this with X)
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x81, '9150X XXXX'  (i have modified this with X)
.Jan 17 14:08:05.566: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=74
.Jan 17 14:08:05.870: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=26 nr=74
.Jan 17 14:08:05.870: ISDN Se0/0/0:15 Q931: CALL_PROC pd = 8  callref = 0x8467
.Jan 17 14:08:05.870: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=27
.Jan 17 14:08:05.906: MGCP Packet received from 10.127.32.29:2427--->
MDCX 89343 S0/SU0/DS1-0/30@BAR05253 MGCP 0.1
C: D000000002179bac000000F500000467
I: 48C7
X: 1e
L: p:20, a:PCMU, s:off, t:b8
M: sendrecv
R: D/[0-9ABCD*#]
S:
Q: process,loop
v=0
o=- 18631 0 IN EPN S0/SU0/DS1-0/30@BAR05253
s=Cisco SDP 0
t=0 0
m=audio 24090 RTP/AVP 0
c=IN IP4 10.226.22.49
.Jan 17 14:08:05.906: MGCP Packet sent to 10.127.32.29:2427--->
200 89343 OK
.Jan 17 14:08:08.246: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=27 nr=74
.Jan 17 14:08:08.250: ISDN Se0/0/0:15 Q931: DISCONNECT pd = 8  callref = 0x8467
        Progress Ind i = 0x8288 - In-band info or appropriate now available
        Display i = 'FALLO TEMPORAL'
        Locking Shift to Codeset 5
        Codeset 5 IE 0x1A  i = 0xD400
Any idea where is the problem???? thanks!!
Green
Does the call go out and back in via the same gateway.
Can we see the
debug q931 of the call going out then back in
Alex
Regards, Alex. Please rate useful posts.
Actually is ok the Gw,
Thanks in advance for your answer, the problem was with de voice port:
sh voice port summary
0/0/1:15        01  xcc-voice   up    down none     none     y
0/0/1:15        02  xcc-voice   up    down none     none     y
0/0/1:15        03  xcc-voice   up    down none     none     y
0/0/1:15        04  xcc-voice   up    down none     none     y
0/0/1:15        05  xcc-voice   up    down none     none     y
0/0/1:15        06  xcc-voice   up    down none     none     y
0/0/1:15        07  xcc-voice   up    down none     none     y
0/0/1:15        08  xcc-voice   up    down none     none     y
0/0/1:15        09  xcc-voice   up    down none     none     y
0/0/1:15        10  xcc-voice   up    down none     none     y
0/0/1:15        11  xcc-voice   up    down none     none     y
0/0/1:15        12  xcc-voice   up    down none     none     y
0/0/1:15        13  xcc-voice   up    down none     none     y
0/0/1:15        14  xcc-voice   up    down none     none     y
0/0/1:15        15  xcc-voice   up    down none     none     y
0/0/1:15        17  xcc-voice   up    down none     none     y
0/0/1:15        18  xcc-voice   up    down none     none     y
0/0/1:15        19  xcc-voice   up    down none     none     y
0/0/1:15        20  xcc-voice   up    down none     none     y
0/0/1:15        21  xcc-voice   up    down none     none     y
0/0/1:15        22  xcc-voice   up    down none     none     y
0/0/1:15        23  xcc-voice   up    down none     none     y
0/0/1:15        24  xcc-voice   up    down none     none     y
0/0/1:15        25  xcc-voice   up    down none     none     y
0/0/1:15        26  xcc-voice   up    down none     none     y
0/0/1:15        27  xcc-voice   up    down none     none     y
0/0/1:15        28  xcc-voice   up    down none     none     y
0/0/1:15        29  xcc-voice   up    down none     none     y
0/0/1:15        30  xcc-voice   up    down none     none     y
0/0/1:15        31  xcc-voice   up    up     none     none     y
After restart that voice port 0/0/1 is running properly althought i still dont know if it have been a phisically problem or whatever...
I only have one question more, when I place a call my calling is my IPPhone, but if I repeat a call, my calling in traces change to the head line, and the Type change too, why??
1st test:
Calling Party Number i = 0x0081, '9158527XX'  -> My iphone
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '91504XXXX'
Calling Party Number i = 0x0183, '914816252'
2nd test  (the same IPhone to the same called number few seconds after)
Calling Party Number i = 0x0183, '9148162XX'  the head line¿?????
        Called Party Number i = 0xA1, '9150492XX'
                Plan:ISDN, Type:National   -> this have changed
Thanks!
Hi Alex,
We are seeing the "Temporary Failure" sometimes when the call goes and back via the same gateway? Is this normal? What is the cause on this?
Thanks.
Michael
1987
