Disconnect Tone
minh pham
Hi guys,
I have a trouble with my CME, with FOX card, I've configured custome-cptone on voice-port FXO, but when I disconect call from PSTN, the call is not disconnected in my softphone.
PSTN --------------------- CME ------------------------- (plar) 8010
I've used CoolEditPro and Wireshark to measure the frequence and cadence, but it doesn't work.
11 Replies 11
On your dial-peer please try the following order.
Dial-peer voice 8010 voip
dtmf-relay h245-alphanumeric h245-signal rtp-nte
under your ephone config:
ephone  1
device-security-mode none
type CIPC
Best Regards
thank you for your answer,
I've tried your suggestion, but it still not work,
have U any idea else, when I end call on my cell phone, the call in my softphone is still ringing. Then I call again, I have busy tone.
What codec is your CIPC using number one and number 2 please compare the following CIPC settings:
Remember as well that the CIPC makes use of the data VLAN.
Play around with the following codec settings and see if it makes a difference?
Best Regards
I don think my issue is codec or VLAN, and I dont use CUCM to register the phone, all my phone register on Router (CME).
Rejohn Cuares
Level 4
Level 4
What is that FOX card? Are you referring to FXO card? If so this document might assist you in troubleshooting your problem.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
Please rate replies and mark question as "answered" if applicable.
hi,
I used this document to configure my FOX card, but it not work correctly, as I description.
Have you tried setting up the CPTONE to the country you are in?
yes, i've tried configure, CPTONE but, my country "VIETNAM" is no defined in Cisco IOS , so I use CoolEditPro and Wireshark to mesure the parameter of Frequence and Candence of Custome-Cptone.
But, it stil not work.
Check them with your ISP what they get on their side and what they expect from you making Intl calls.
Best Regards
Jairus C
Is there a disconnect tone feature on Cisco desk phones that determines if a call has already been disconnected? Is this something that can be added or configured as a feature? Thank you!
Device model: Cisco IP Phone 8861
@Jairus C Two things, first of all your question is off topic to the OP question and secondly this post is very old, all the way back from 2014.
Response Signature
