'DisconnectText no resource (47)' on VoiceGateway
Hi sir.
Our VG refused to setup LongDistance Call Irregular ,with the log message 'DisconnectText no resource (47)' .
I have checked the E1 resource was Ok.
Despite it,I am not sure whether the DXP resource is enough.The related CLI is below:
sho dsp all
sho voice dsp voice
show voice dsp active
I can see many DSP resource with IDLE status
I DO think the root cause is some like DXP resource.Would you pls give me some feedback?
Gold
Re: 'DisconnectText no resource (47)' on VoiceGateway
It even depends on which endpoint caused this message to be logged. Would it be possible for you to get "debug isdn q931" for one such call and add it here. By Resource unavailable, it does not refer to the DSP alone. There could be multiple other reasons as well. For example if the CM for any reason was trying to invoke a MTP for this call and could not, it would send a disconnect to the GW with Resource Unavailable message.
So the debug, version of CM, IOS ver on the Router would help in issolate the issue
Thanks mchandak.I'll try it later.
The version information is shown below,
--3800 Software (C3825-SPSERVICESK9-M), Version 12.4(9)T1, RELEASE SOFTWARE (fc2)
-ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
-System image file is "flash:c3825-spservicesk9-mz.124-9.T1.bin"
--CCM,4.1(3)sr3c
In addition,it's just the time when LongDistance was failed,we could setup DID through the same E1 line.
And also,Since there are in all 4 PVDM2-48 and 3 PVDM2-64 installed in both VG,I'm wondering why the transcoding max session can only support to 3.
02(config)#dspfarm profile 1 transcode
02(config-dspfarm-profile)#max sessions ?
<1-3> Number of sessions assigned to this profile
Hi mchandak,would you pls kindly help me check the debug log ,many thanks.
ANI:85264933 DNIS:905352122299
2306141: *Jul 10 16:30:14.624 PRC: ISDN Se2/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling
num 85264333
2306142: *Jul 10 16:30:14.628 PRC: ISDN Se2/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called
num 05352122266
2306143: *Jul 10 16:30:14.628 PRC: ISDN Se2/1:15 Q931: TX -> SETUP pd = 8 callref = 0x2517
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839D
Exclusive, Channel 29
Calling Party Number i = 0x0081, '85264333'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '05352122266'
2306144: *Jul 10 16:30:14.648 PRC: ISDN Se2/1:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xA517
2306145: *Jul 10 16:30:15.104 PRC: ISDN Se2/1:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xA517
Cause i = 0x82AC - Requested circuit/channel not available
Progress Ind i = 0x8288 - In-band info or appropriate now available
2306146: *Jul 10 16:30:15.104 PRC: ISDN Se2/1:15 Q931: call_disc: PI received in disconnect; Postpone sending
RELEASE for callid 0xA2A0
2306147: *Jul 10 16:30:15 PRC: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 6ABF43 C14CD11D
A9200000 AC104BFD, SetupTime *16:30:15.098 PRC Tue Jul 10 2007, PeerAddress 905352122266, PeerSubAddress ,
DisconnectCause 2F , DisconnectText no resource (47), ConnectTime *16:30:15.108 PRC Tue Jul 10 2007,
DisconnectTime *16:30:15.108 PRC Tue Jul 10 2007, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0,
TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
2306148: *Jul 10 16:30:15.108 PRC: FEATURE_VSA fn:TWC,ft:07/10/2007
16:30:14.624,cgn:85264333,cdn:905352122266,frs:0,fid:804956,fcid:6ABF43C14CD11DA9200000AC104BFD,legID:C492F
2306157: *Jul 10 16:30:19 PRC: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 6ABF43 C14CD11D
A9200000 AC104BFD, SetupTime *16:30:14.618 PRC Tue Jul 10 2007, PeerAddress 85264333, PeerSubAddress ,
DisconnectCause 2F , DisconnectText no resource (47), ConnectTime *16:30:19.108 PRC Tue Jul 10 2007,
DisconnectTime *16:30:19.108 PRC Tue Jul 10 2007, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0,
2306158: *Jul 10 16:30:19.112 PRC: FEATURE_VSA fn:TWC,ft:07/10/2007
16:30:14.620,cgn:85264333,cdn:905352122266,frs:0,fid:804955,fcid:6ABF43C14CD11DA9200000AC104BFD,legID:C492E
Gold
Well .. in this case the Telco disconnected the call with "Requested circuit/channel not available". Looks like the issue is with the Telco. You might want to get back to them and check if this E1 is running clean or not. For some reason they did not fwd the call, as it was unable to allocate a channel to it.
And with reference to Transcoding session, How many E1's do you have on the router and where are these PVDMs on the router, how many on the motherboard and NM. Can you attach "show diag". Also, incase you have even configured conference sessions on the router, remember that the same DSP cannot be shared by CFB and XCODE
3934
