Community Member
DISCUSSION (No Title)
Hi, i can't delete Calling Search Space (CSS) from the CUCM page, i have this message:
Delete failed. The pkid column in the callingsearchspace table in the database is being
referenced from another table. Please check the dependency records, remove the reference,
and then try the delete again.
I want to delete the CSS named: CSS-Fax-Boulogne
With the CUCM's CLI i use this command:
- run sql select * from callingsearchspace
and seen this: 353428bb-31e8-5745-406a-df73f0050af6 CSS-Fax-Boulogne                NULL
But when i use this command:
admin:run sql select fknumplan from callforwarddynamic where fkcallingsearchspace_cfa = "353428bb-31e8-5745-406a-df73f0050af6"
fknumplan
admin:run sql select dnorpattern from numplan where pkid = "353428bb-31e8-5745-406a-df73f0050af6"
dnorpattern
admin:
i have no result, can you help me please for delete the unsed CSS?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
check to ensure there are no
check to ensure there are no BAT templates referencing it.
Chris
Chris
Purple
Hi, check the link if it
check the link if it helps.
https://supportforums.cisco.com/document/119616/unable-delete-couple-calling-search-space-form-cucm-page
regds,
aman
Community Member
I had already looked at this
I had already looked at this post before open my post
but thanks for your reply
Community Member
Thanks a lot, i find this CSS
Thanks a lot, i find this CSS in Templates and device Pool, et CSS Subscriber of device.
22
