Community Member
DISCUSSION (No Title)
Hi, If you are forwarding your calls thru offnet to a Cell Phone, can you receive the VM message on your Cell Phone and also receive an email with the VM message? The email could be the work email and/or a person email such as a  gmail or yahoo email.
Can this be done?
Nancy
1 ACCEPTED SOLUTION
Community Member
It was a pleasure, please
It was a pleasure, please rate if it was help the information
Community Member
Hi,As far as I know there
As far as I know there should be one or another.  When a call is picked up (VM) from the PSTN there´s no way to let the unity know to take the VM as well.
But if you miss a call from your Cisco IP Phone you can have 2 options:
1- You can get a notification letting you now that you missed a call , if the person who calls does not leave a VM(This is with a third party vendor)
http://www.telisca.com/docs/MCEA_EN.pdf
2- Integrating unity connection with exchange, The call comes in, nobody picks up, the call get forwarded to voicemail, the person leaves a VM, and when the person finish the call, the voicemail will be rerouted to your Ip phone, as well as your e-mail with the VM attached to it.
Please rate it if  this helps.
Community Member
3- As per gmail and yahoo,
3- As per gmail and yahoo, you will need to configure SMTP vmail to Gmail
www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/administration/guide/8xcucsagx/8xcucsag200.html#wp1049727
Community Member
Thank you so much. These
Thank you so much.
These options are only for VM that is not sent offnet to a personal cell phone or landline, correct.
Appreciate all yout help on this.
Nancy
Community Member
That´s correct Nancy!Those
Those options are only for VM that is not sent offnet
Community Member
Thanks so much for all your
Thanks so much for all your help.
Nancy
Community Member
9
