Disk/logging is 100%
On one of my CUCM the Disk/logging is showing 100% used, so what can be done to cleanup this partition.
I tried purging the CDR & CMR data but did not help much...
any idea what could be issue for high disk utilization??
My CUCM is running 5.1.2.
1 REPLY
Red
Re: Disk/logging is 100%
Purge CDR & CMR data won't save you space. Because the space for CDR/CMR DB was pre-allocated during installation.
use "show status" to see which partition is full.
If it's the "common" partition full, you maybe run into bug CSCsj95433.
Michael
http://htluo.blogspot.com/
277
