DISK SPACE FULL : Diskactive full ( 100%)
Hi ,
I have a Disk problem with my CUCM :
The result of "show status" command is :
                       Total           Free           Used
Disk/active         12316656K         12728K       12178796K (100%)
Disk/inactive       12316672K       11658176K         32828K (1%)
Disk/logging       43621124K      12413912K       28991368K (71%)
Please, there is any way to clean  space "Disk/active" ?
thanks in advanced
Hicham
Hi Hicham,
What is the callmanager version that you are currently using.
Also have you performed an upgrade from 5.x to 7.x and since then you have started experiencing this issue.
Hi nikshah,
Please find the exact version of the CUCM :
1- show status
admin:show status
Host Name   : ccm1
Date         : Thu May 31, 2012 09:31:51
Time Zone   : Africa/Casablanca
Locale       : en_US.UTF-8
Product Ver : 5.1.3.1000-12
Platform Ver : 2.0.0.1-1
Uptime:
09:31:52 up 32 days, 20:24, 1 user, load average: 0.13, 0.11, 0.11
CPU Idle: 94.42% System: 00.51%   User: 04.57%
IOWAIT: 00.00%     IRQ: 00.00%   Soft: 00.51%   Intr/sec: 124.24
Memory Total:       2053816K
       Free:         19780K
       Used:       2034036K
     Cached:         917336K
     Shared:             0K
     Buffers:         68656K
                       Total           Free           Used
2 show hardware
admin:show hardware
HW Platform       : 7835H2
Processors       : 1
Type             : Intel(R) Xeon(R) CPU           5140 @ 2.33GHz
CPU Speed         : 2333
Memory           : 2048 MBytes
Object ID         : 1.3.6.1.4.1.9.1.584
OS Version       : UCOS 2.0.1.0-70
RAID Details     :
Smart Array P400 in Slot 1
   Logical Drive: 1
   Fault Tolerance: 1+0
   Heads: 255
   Sectors Per Track: 32
   Cylinders: 17562
   Stripe Size: 64 KB
   Status: Ready for recovery.
   Array Accelerator: Enabled
   Has Data On Drive: True
   Unique Identifier: 600508B10010453953563435384C0001
   Preferred Controller Chassis Slot: 1
3 show version active
admin:show version active
Active Master Version: 5.1.3.1000-12
Active Version Installed Software Options:
localeinstaller
cm-locale-fr_FR-5.1.1.2000-1.cop
cmterm-7937-1-4-3-SCCP.cop
cmterm-7937-sccp.1-4-1.cop
cmterm-7937-sccp.1-0-1.cop
For now, we just plan to upgrade the CUCM .
Thanks in advance
Hicham
there are a lot og bugs with regards to space on cm 5.x the one that isnt fixed till cm 6.1.x
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsj95433
you might want to engage tac and they can setup root and delete/take care of the files.
360
