display a username from a directory book instead of a caller ID for incoming call - cucm 7
Is there any way so that when there is an incoming call, it will display a username from a directory book instead of a caller ID?
i am using CUCM 7
Rachel
Are you referring incoming calls from inter cluster or from PSTN?
Sandesh Rao
Re: display a username from a directory book instead of a caller
Hi Rachel.
If you mean incoming call from PSTN , this is not mentioned on CUCM features.
You can run external script on Voice Gateway developed by Paolo Bevilacqua.
Search number2name here on this forum.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Rachel,
what about using 3rd party app?
I can recommend to follow this link: http://www.2ring.com/NewJuice to get more information.
Also, the FREE or TRIAL license is obviously available.
Martin
160
