Community Member
Display called number on Jabber PC
Hello
I have Cucm 9.1.2.10000-28 and I have CSF device for PC Jabber.
When i make an externalcall on mobile the I remove prefix 0 and add 98 followed by mobile number,
on VG I have the following dial-peer
dial-peer voice 31 pots
tone ringback alert-no-PI
description CHIAMATE USCENTI su bri0/0/0 con #
destination-pattern 98T
fax rate disable
direct-inward-dial
port 0/0/0
So this procedure works but on display of Jabber and on history of Jabber i have 98 followed by number.
Is it possible to display on Jabber effective number ?
is it possible to have on historical call 0 followed by effective number?
Thanks a lot for your help
Cesare
Re: Display called number on Jabber PC
You can do it with a voice translation pattern on your VG where you bring the mobile number in and on the dialpeer your translation profile outgoing you can strip the zero and add the 98 or take the number without the zero and add the 98
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Voice CCIE #37771
Community Member
Hello
I did understand how the voice traslation will be used in my issue.
Just make trasformation of number from client Jabber to VG:
client make   03xxxxx (mobile call) -> mach pattern 03.! predot and prefix 98 so i on vg i have 983xxxx
in following dial peer  strip 98 and call correctly 3xxxx but on jabber display i have 983xxxx and in history too.
On call manger in service parameters i found in device this parameter:
Name Display for Original Dialed Number When Translated
but doesn't work
thanks
Cesare
then you can have a look under call routing at Transformation Patterns => Called Transformation Pattern, create a CSS and PT for that apply it to the DevicePool of the Jabber phones.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/9_0_1/ccmcfg/CUCM_BK_CDF59AFB_00_admin-guide_chapter_0110000.html
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/admin/7_0_1/ccmcfg/b03cldpt.pdf
Voice CCIE #37771
Community Member
Hello
I make in service parameter
Always Display Original Dialed Number in true
with this parameter in true works and on jabber i have 03xxx on display and in history too.
well that is great news!... congrats.
Voice CCIE #37771
121
