Display caller ID for outbound calls
Dear Team,
In the cisco VOIP environment i manage,
All VoiP phones were set to use company caller id (our reception number) for all outbound calls.
Now i am asked to change and the requirement is, display each individual's caller id for their external calls.
where do i have to start ...in our side or at the SIP provider ?
Erin
1 ACCEPTED SOLUTION
Hello Erinedison I hope that
Hello Erinedison
I hope that you are doing so well.
if you need to enable DID for each DN. you have to do the below:-
1- define the DIDs which you have from your provider .
2-Define the number of users who need DID.
3- You have to do the following for one user who need to enable DID.
lets say your DID range is 8579440  8579449. So you have to know that you need to assign a number for example 9441 to one of users . so on cucm - phone  -  line -configure DN as 9441 on the bottom of the page od directory number configuration  you will find external phone number mask , configure it as 8579XXX. So when user  dial for external call , his DID 8579441 will appear as you configured ,and do test for one user , after that apply for all users as the same way.
please rate all useful information
Start by mentioning if this
Start by mentioning if this is CUCM/CME and version
Most likely that's because of your config, some telcos can do this for you. You'll need to look at your config.
You do have DIDs, right?
java
if this helps, please rate
www.cisco.com/go/pdi
Thanks Jaime, its CUCM 8.5
Thanks Jaime,
its CUCM 8.5.1
Yes we do have DID's
Look at DN level, route
Look at DN level, route pattern, route list and GW/trunk level to see where this is configured.
java
Hello Erinedison
Thank you,i shall try and
Thank you,
i shall try and keep you all informed.
Try creating a sips profile
Try creating a sips profile class, and then modify the invite headers. where XXXX is the internal extension, 10.10.10.10 is the SIP IP, and ZZZZZZ represents the number the call is meant to come from.
voice class sip-profiles 100
request INVITE sip-header From modify "sip:XXXX@10.10.10.10" "sip:ZZZZZZZ@10.10.10.10"
And then under Voice Service Voip:
Sip
sip-profiles 100
Thank you ,i shall try and
Thank you ,i shall try and let you know how it goes..
Erin
84
