Display calling name through QSIG (cucm v7.1,gw 2821 H323,Nexspan)
Hi all,
I have a CUCM v7.1 and an Aastra Nexspan linked by QSIG.
Calls works fine between the 2 systems, but I can't display the calling name in the two sides.
The gateway is a cisco 2821 router, configured as a H323 gateway.
Here's the confiruguration of the gw:
voice service voip
qsig decode
allow-connections h323 to sip
allow-connections sip to h323
supplementary-service h450.12
h323
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn timer T310 120000
isdn protocol-emulate network
isdn incoming-voice voice
isdn supp-service name calling profile Network-Extension operation-value-tag local
isdn send-alerting
isdn negotiate-bchan
isdn sending-complete
isdn outgoing ie facility
isdn outgoing ie extended-facility
isdn outgoing display-ie
isdn outgoing ie connected-number
isdn outgoing ie caller-number
isdn outgoing ie caller-subaddr
isdn outgoing ie called-number
no cdp enable
here debug Q931  from 13163 (aastra phone)  to 14504 (Cisco Phone): Display calling name : "unknown, external call":
*May 27 09:48:09.296: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0018
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18385
                Preferred, Channel 5
        Facility i = 0x91AA068001008201008B0100A10B02010006042B0C09008400
        Progress Ind i = 0x8083 - Origination address is non-ISDN
        Called Party Number i = 0x80, '14504'
                Plan:Unknown, Type:Unknown
        Sending Complete
*May 27 09:48:09.300: ISDN Se0/2/0:15 **ERROR**: isdn_init_fac_data: No Opval 0
*May 27 09:48:09.304: ISDN Se0/2/0:15 **ERROR**: isdn_init_fac_data: No Opval 0
*May 27 09:48:09.320: ISDN Se0/2/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8018
        Channel ID i = 0xA98385
                Exclusive, Channel 5
*May 27 09:48:09.460: ISDN Se0/2/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x8018
        Facility i = 0x9FAA068001018201018B0100A10902020EF10201018000
*May 27 09:48:10.944: ISDN BR0/0/1 Q931: RX <- CALL_PROC pd = 8  callref = 0xF4
        Channel ID i = 0x89
                Exclusive, B1
here debug Q931 from 14504 (Cisco Phone) to: 13163 (aastra phone) Display calling name : "14504":
*May 27 09:48:14.608: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0581
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA18382
                Preferred, Channel 2
        Facility i = 0x9FAA068001018201018B0100A10902020EF20201008000
        Calling Party Number i = 0x0081, '14504'
        Called Party Number i = 0x80, '13163'
*May 27 09:48:14.656: ISDN Se0/2/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8581
*May 27 09:48:14.712: ISDN Se0/2/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8581
        Facility i = 0x91AA068001008201008B0100A10B02010006042B0C09018400
        Progress Ind i = 0x8081 - Call not end-to-end ISDN, may have in-band info
*May 27 09:48:15.712: ISDN Se0/2/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8581
        Facility i = 0x91AA068001008201008B0100A10B02010006042B0C09028400
        Connected Number i = 0x80, '13163'
Thanks for your help!
Everyone's tags (3)
Re: Display calling name through QSIG (cucm v7.1,gw 2821 H323,Ne
Try adding this:
voice service voip
h323
  h225 display-ie ccm-compatible
I had to do that to get my inbound cnam to work.
Hope this helps
Rick
Hi Rick,
thanks for your help, but I can't enter this command:
voice service voip
h323
it's an Unrecognized command. Here are the available option after h225:
(conf-serv-h323)#h225 ?
       alt-ep            Alternate endpoint configuration
       connect-passthru  Connect Pass through
       h245-address      global control for h225 reporting of h245-address GW
       id-passthru       Protocol identifier pass through
       listen-port       Call Signaling Port (default 1720)
       signal            Specify signaling options
       start-h245        global control of initiation of H.245
       timeout           Specify timeout for maintaining connections
Can you help me again?
the System image file is "flash:c2800nm-spservicesk9-mz.124-15.T12.bin"
Sorry for the last post,I upgrade the IOS version in Version 12.4(11)XW10, I can add the command but it still doesn't work...
I change the gateway protocol into MGCP, but the problem is the same... Is someone have an idea?
Ok today the name is display when a Cisco Phone call an Aastra Phone, but not in the other direction...
here's an extract of the gw config:
voice service voip
qsig decode
h323
  h225 timeout ntf 300
voice class codec 1
codec  preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3  g729br8
voice class codec 2
voice  class h323 1
h225 timeout tcp establish 5
no ip address
encapsulation hdlc
isdn  overlap-receiving
isdn map address *. plan isdn type unknown
isdn supp-service name  calling ie 40 cs 0 profile Network-Extensions operation-value-tag local
no cdp enable
Did you find resolution to this problem? I have the exact same setup with the exact same issue.
Hi Vladimir,
I had to use the external directory of Aastra Nexpan to display the name on Aastra phone. I was not able to use the name from the qsig frames...
4867
