Community Member
Display FAC in CDR
Someone know if in the CCM 5.0(4) version , the FAC is displayed in the CDR, i know that in the 5.1(3)version it can but i think that this is an unsupported feture in the version 5.0(4)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/5_1_3/car/caranrpt.html
Re: Display FAC in CDR
AFAIK the DB scheme is the same for the 5.x version so the FAC should be in there
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Hi javalenc,
Please check the document Getting Started with CDR Analysis and Reporting, it is diferent in the part of Display FAC in CDR because it apears only in the guide of the 5.1(3) version.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/5_0_4/car/caranrpt.html
think ur right, the doc for handling the reports only show CMC as an option
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/5_0_4/car/carsyrpt.html#wp1086010
javalenc
java
Bronze
I just loaded up 5.0(4) and don't see an option for "Display FAC in CDR". That comes in with 5.1 service parameters.
Don
Community Member
now I have problem CUCM5.1 CDR csv export is not included FAC.
I already choose In the Clusterwide Parameters (Device - General), Diaplay FAC in CDR set to "True"
But in the CDR export csv file is not shown FAC in any colume.
Is there is anybody found the same problem like this?
755
