Display name for Trunk?
Tommer Catlin
I hunted around and could not see if there was an easy way to do this:
Route Pattern 5555 ----->SIP trunk------>PSTN
On the display, can it show 5555 - PSTN, instead of just 5555 of the called party?   I know in Unity when you connect to the VM server, you can manipulate the connected display name to show this.  Is it the same with other trunks as well?
Thanks!
Hi Tommer.
I would just use a workaround.
I would create a directory number 555 , specifying  Alerting Name , in partition A with a CFWA to route pattern 555
put Partition A in the CSS assigend to phones.
Try it and let me know.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Thanks I will give it a try!
