Display Name on incoming SIP URI calls, how to display domain suffix?
we have cucm 10.5 with jabber 10.5 connected with a sip trunk to VCS 8.2. When an external sip uri call, for example steffen.bruening@jabber.com is routed through the VCS to the CUCM and then to my Jabber for Windows, the call popup and also the call windows displays only the firstname.lastname, which is the display name for this calling party in the sip invite message to the CUCM.
From: " steffen.bruening" < sip:steffen.bruening@jabber.com>
Is there a chance to display instead the full URI with domain suffix?
On Sip Trunk and CSF devices "Use FQDN names" is enabled in the SIP Profiles.
I have the same problem.When
When I look at the traces the INVITE from the VCS is correct with Jens.Lantermann@jabber.com (Calling Party),
and the Device INVITE Displays Jens.Lantermann@<<cucm-IP>>.
Has andbody solved this problem?
i have the same issue,did
did anyone solved this problem?
I have found the solution of
I have found the solution of our problem.
I need to enable "Use FQDN names" in any SIP Profile who should use the full FQDN.
Then everything works.
528
