Community Member
Display of Corporate Directory on IP Phones
On the IP phones when we search for a particular user (in Corporate Directory), the search result displays in this order "Lastname, Firstname". How to change it to display in the order of "Firstname, Lastname " ??
Can someone give me some inputs on this
Community Member
Re: Display of Corporate Directory on IP Phones
hi, i think this should work
telephony-service
directory first-name-first
Community Member
I'm using CCM 4.2(1). Where should I specify this?? Could you pls explain me more on this..
Hall of Fame Super Red
Hi RV,
The config that Okanlawon mentions only works for CME :( There is no built-in CCM config that can be set to change the search results. You can however get into some XML tweaking in the xmldirectorylist.asp that might allow you to change this (these changes would be lost during any CCM upgrade and may not be Tac supported). I am not a developer so I have no insight on what exactly is required. Maybe this could get you started;
Cisco IP Phone Services Software Development Kit
http://www.cisco.com/en/US/products/hw/phones/ps379/products_data_sheet09186a00800925a8.html
Also, here is a good thread that touches on this subject;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Phone%20Services%20for%20End%20Users&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dd9577b/0#selected_message
Hope this helps!
Rob
Please remember to rate helpful posts.....
Community Member
Any idea how can I achieve this in CUCM 6.0??
In CCM 4.x I could do this as the files were easily accessible, but how can we get this done with CUCM 6.x...
This is not supported by the cisco TAC,
however you can to the following:
- Go to your CCM server and look for the xmldirectoryinput.asp that is under
C:\CiscoWebs\IPPhoneServices\CCMCIP
- Open this file and look for the following output:
Directory Search
Enter search criteria
http://localhost:80/CCMCIP/xmldirectorylist.asp
First Name
f
A
To put LastName:
Change this line : First Name to
Last Name
Last Name
l
A
To put FirstName:
Change this line: Last Name to
First Name
Community Member
Hi Rob & jbarcena,
Both of your inputs were very helpful and I could acheive my desired results. Thanks a lot for your excellent support.
Community Member
Is there a way wherein we can achieve this on version 8.6 of cucm.
Prakash
250
