Community Member
display phone status...
Is there a way I can visit a page on CME to view who is on a call? What is another easy way to do this? TIA.
Bronze
Re: display phone status...
you can check this out
http://www.cisco.com/en/US/products/ps7067/index.html
or use BLF for simplicity.
Community Member
What is BLF?
Busy Lamp Field
you can see the status of other DNs using it, you bind it to a phone button
java
if this helps, please rate
java
www.cisco.com/go/pdi
Bronze
sorry wasnt too clear. take a read im sure this is what you might be looking for
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmepres.html
we dont know your CME version so make sure you meet the requirements stated at the begining of the document
Community Member
I need another application to be able to poll if someone is off-hook or not. What would be ideal is if that application could view it on the GUI front-end... http://IP/ccme.html
Have you seen something like that?
Bronze
check out the call connector i posted. im not too sure (smoeone might be able to answer correctly) but if you are looking for your operator to view it like this i think arcexpress does this.
instead of shooting out different programs
do you need this for all phone users or just specific?
Community Member
I think that would be a bit of an overkill. I'd just like a simple table of DNs with their on/off-hook status.
It needs to be for all users.
I'm looking at the /gui files and it looks like it might be possible to modify something to create a table from "show ephone | include Active Call". I could issue that command then play with the output to display it on the web page. Is it common to modify the files in the /gui directory?
Bronze
youre probably going out of my realm of experience with the modification but if you do get through with something like that id appreciate a response.
good luck
310
