Community Member
Displaying a Message(Alert) on IP Phones
hi,
My customers' IP phone extentions are getting changed from 4 to 5 digits.
To remind the callers of this, is there any way I can display permanently a static message on the IP Phones screen?
Red
Re: Displaying a Message(Alert) on IP Phones
You may change the wallpaper of the phone.
Michael
Bronze
If you had Informacast, you could send messages that way to the screen. I'm sure some XML programmers could figure out some way to do this. This is definitely not "out of the box."
Please rate if it helps
Hall of Fame Super Silver
Correct, check out SingleWire InformaCast product fromerly known as Berbee InformaCast.
Simply google it.
Chris
177
