Displaying company name on IP Phone
On 7940 IP Phone, there is black strip on the top that displays time, date and ext no. I want to display our company name on that strip. Does anyone know how to do that?
Hall of Fame Super Red
Re: Displaying company name on IP Phone
Hi Abhijit,
This is available in CME only, not CCM at this point in time. This would be on the "lower" banner location;
Have you looked into using this CME Feature?
System Message Display
The System Message Display feature allows you to specify a custom text or display message to appear in the lower part of the display window on display-capable IP phones. If you do not set a custom text or display message, the default message "Cisco Unified CME" is displayed.
When you specify a text message, the number of characters that can be displayed is not fixed because IP phones typically use a proportional (as opposed to fixed-width) font. There is room for approximately 30 alphanumeric characters.
The display message is refreshed with a new message after one of the following events occurs:
Busy phone goes back on-hook.
Idle phone receives a keepalive message.
Phone is restarted.
The file-display feature allows you to specify a file to display on display-capable IP phones when they are not in use. You can use this feature to provide the phone display with a system message that is refreshed at configurable intervals, similar to the way that the text message feature provides a message.
The difference between the two is that the system text message feature displays a single line of text at the bottom of the phone display, whereas the ***system display message feature can use the entire display area and contain graphic images.
SCCP: Modifying System Message Display
To modify the system message display on phone screen, perform the following steps.
SUMMARY STEPS
1. enable
2. configure terminal
3. telephony-service
4. system message text-message
5. url idle url idle-timeout seconds
6. end
System File Display: Example
The following example specifies that a file called logo.htm should be displayed on IP phones when they are not in use:
telephony-service
url idle http://www.abcwrecking.com/public/logo.htm idle-timeout 35
From this good CME doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelabel.html#wp1032353
Hope this helps!
Rob
Just use the "description " command for the main ephone-dn on the phone. So if you have:
ephone-dn 1
description XYZ Company
number 3000
ephone 1
mac-address 0000.0000.0000
button 1:1
The phone should display on the top black bar of the phone:
426
