Displaying incoming calls name on cucm 7.x
Can anyone tell me what should be done so to display names instead of Ext numbers for incoming calls
Ihssan Alibouch
1 REPLY
If you mean for internal calls just configure the caller ID under the line.
If you're asking about looking up names for external calls from somewhere, we don't have that in any CUCM release.
Look at Paolo's script for that.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
521
