Distinctive ringtone feature for cme
Hi guys,,
i need to configure distinctive ringtone feature in cme (different ring from pstn and internal extension)
,, but i have one confusion below in the description  it is saying that ring pattern for all types on incoming calls..which means if i configure "ring external".. it choose  one external ring pattern for all internal calls and external calls?
or it will choose different ringing for external calls.
cme admin guide
Step 5
ring
{external | internal | feature} [primary | secondary]
Example: Router(config-ephone-dn)# ring internal
Designates which ring pattern to be used for all types of incoming calls to this directory number, on all phones on which the directory number appears
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Distinctive ringtone feature for cme
Hi Hamid,
Yes, if you use (config below) you will receive a different ring for External (PSTN) calls vs Internal calls
Router(config-ephone-dn)# ring external
Cheers!
Rob
Hi Hamid,
Just for External calls
Here is a better description;
Distinctive ring is used to identify internal and external incoming calls. An internal calls is defined as a call originating from any Cisco Unified  IP phone that is registered in Cisco Unified CME or is routed through the local FXS port.
Cheers!
Rob
Hi Rob,
thanks for your reply, but i am asking if issue this command
will it ring differently for internal calls and externals call PSTN,,
Hi Hamid,
Cheers!
Rob
1408
