06-19-2008 10:05 AM - edited 03-15-2019 11:24 AM
hello,
i have CUCM6.0 and H323 gateway, my need is to play internal moh for internal calls to CCM, and play another moh music that i will stock at gateway for external calls.
How can i do that ?
i have tried to change MRGL with one server that have the multicast activated, but it doesn't work.
thanks at advance.
06-19-2008 11:17 AM
Unfortunately there is no way to acomplish this as the moh source file configured on the phone (or via a device pool) is played, and there is no way to make a distinction from internal vs external caller. MRGL only controls which MOH server is invoked.
I guess the one way to do it though could be to use a different MOH server for the GW (via different MRGL) and upload the MOH source file under the same name to the other server.
Chris
06-19-2008 12:14 PM
the only possible way i could think of doing this would be to have 2 separate MOH servers both using the same multicast IP address, but you would need to configure the network so that the ip phones listen to the stream from one MOH server and the GW to other one when told to.
this of course would mean you would need to configure ACLs and/or different subnets on which the streams would not mix in the network
not sure if you see this as a possible option
javalenc
if this helps, please rate
06-20-2008 07:28 AM
hello,
thanks for your reply.
My request if it's possible to isolate the publisher and susciber in order to have 2 Moh servers.
thanks
06-20-2008 01:30 PM
you can have an MOH server per CUCM server, so that's possible. not sure if i'm understanding correctly the question, can you elaborate?
javalenc
06-24-2008 02:00 PM
hello,
i mean that if i can to have 2 MOH servers equal.
the first at the publisher and the second at the subscriber.
06-24-2008 04:06 PM
the configuration for the MOH server in the same cluster is replicated on all servers running the MOH, so not sure what you mean
javalenc
