07-28-2009 12:32 AM - edited 03-18-2019 10:29 AM
I want for each phone à distinctive ring for internal and external call.
is that possible? if yes please help.
thanks
Solved! Go to Solution.
07-28-2009 07:37 AM
No, it just changes the cadence of the ring for calls. They're not 2 different rings.
java
if this helps, please rate
07-28-2009 06:09 AM
hi,
cisco said in datsheet, call manager 6.1 can do that, but i can't find any doc to configure it.
all help will be very very apreciated.
thanks
07-28-2009 06:17 AM
Hi Said,
Have a look at these threads, there is some good related info :)
*Distinctive ring for on- and off-net status this is a "distinctive cadence" not a different ring tone :)
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40^1%40%40.2cc17b8c/2#selected_message
Hope this helps!
Rob
07-28-2009 06:35 AM
i have a look at this links.
i will back to you
thank you.
07-28-2009 06:52 AM
hi Rob,
the second link doesn't work.
but the first , i can see thai in datasheet. but i don't understand what they mean by "Distinctive ring (on-net vs. off-net)".
Perhaps, echc phone can give 2 different rings, one for internal call, and other for external call.
07-28-2009 07:37 AM
java
07-28-2009 08:46 AM
thank you java.
so i understand that configuring 2 differnt ring is impossible . it's right ? please confirm.
07-28-2009 08:56 AM
NOT possible
java
07-28-2009 08:58 AM
Thank you veeeeeery mutch.
