Distintive ring for internal and external call
I want for each phone à distinctive ring for internal and external call.
is that possible? if yes please help.
thanks
1 ACCEPTED SOLUTION
Re: Distintive ring for internal and external call
No, it just changes the cadence of the ring for calls. They're not 2 different rings.
java
if this helps, please rate
java
www.cisco.com/go/pdi
hi,
cisco said in datsheet, call manager 6.1 can do that, but i can't find any doc to configure it.
all help will be very very apreciated.
thanks
Hall of Fame Super Red
i have a look at this links.
i will back to you
thank you.
hi Rob,
the second link doesn't work.
but the first , i can see thai in datasheet. but i don't understand what they mean by "Distinctive ring (on-net vs. off-net)".
Perhaps, echc phone can give 2 different rings, one for internal call, and other for external call.
java
java
thank you java.
so i understand that configuring 2 differnt ring is impossible . it's right ? please confirm.
NOT possible
java
java
Thank you veeeeeery mutch.
302
