Divert to Extension (Not Voice Mail)
Jacob Berger
Level 2
Level 2
i setup a new voicemail profile so that the idivert/divert button would call a extension (not voice mail)
beside the fact that these users wont be able to use the normal voicemail system, could this cause any other problems?
thanks
Mark Lyman
Level 5
Level 5
That's a pretty cool idea. I'd be curious to know how it works out.
Hi Jacob.
It work for sure, and I used it in the past.
The only limit I can see is the use of the voice mail, that would be not allowed through message button, and the forward all to VM that should be done dialing the voicemail pilot after CFWD ALL softkey.
That's all
Cheers
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
