Community Member
DLU or CUWL
I have to gather information of a CUCM, how can I find out which type (DLU or CUWL) of licenses is used ?
Thanks for help
DLU or CUWL
I am not aware of any way that you can do this just by looking at the CUCM config as CUWL effectively just gave you DLUs (in 9.x this has changed and DLUs are gone)
I would try to locate the PAK certificates which would have been supplied when the system was originally installed as these will show what type of licensing was ordered.
Be aware though Cisco did start allowing CUWL and UCL licensing to be used on the same cluster in some 8.x releases.
Purple
DLU or CUWL
Hi ,
You can find the DLU being used by each model under Licensing ------> license unit calculator for call manager version till 8.
this gives you the number of units consumed per device , number of units consumed and current number of devices.
regds,
aman
156
