DLU to UCL
Dear All,
Can we change the license type DLU to UCL without upgrading CUCM version (current v.8.6.2) and without active UCSS/ESW contract?
Thanks.
2 ACCEPTED SOLUTIONS
VIP Purple
Hi Frank,Before u do major
Hi Frank,
Before u do major upgarde, upload all un-unsed DLUs to Call manager.
Secondly,if u have any free DLUs, that would get converted to UCL Enhanced/ Enhanced Plus after the major upgrade is done . This can be done only after u do successful migration to CUCM 9 or 10.
Further , if u purchase UCL now for CUCM 8 , the same would work as DLU after u upload the licenses in CUCM 8.x.
Un-used DLUs get converted to enhanced UCL be default if u do not mention to licensing team.
refer the link
https://communities.cisco.com/thread/41026
regds,
aman
VIP Purple
Hi Frank,Analog phones/6901
Hi Frank,
Analog phones/6901 /3905 do not consume any DLUs but we need to purchase Analog phone Licneses not DLU , had it been DLU case or they were not End of Sale
But now it is UCL essential in CUCM 8 or CUCM 9 since DLU is end of sale.
Device Type - Cost in DLUs
Cisco VGC Phone (Voice Gateway Controlled, e.g. behind VG248)
Cisco VGC Virtual Phone (Voice Gateway Controlled, e.g. behind VG248)
Analog Phone
CTI Port
0 -DLU's
I suggest reading the link
https://supportforums.cisco.com/discussion/11824511/ucl-and-vg248
regds,
aman
VIP Purple
Hi Frank,Can u explain what
Hi Frank,
Can u explain what is the reason behind this  since even if u have UCL , at the backened, DLUs would work in CUCM 8.6.2?
If u are planning to upgrade to major CUCM version , then, u need to have ESW/UCSS contract and used DLUs would get converted to UCL after the mail is initiated to licensing team.
regds,
aman
Hi Aman,Thanks for the reply
Hi Aman,
Thanks for the reply,
Currently we have only DLU license.
Used -7780
Free  - 620
 As DLU is going to eos from next january. we cant buy extra dlu bundles.
So i need to convert our all DLU (Used and free ) to UCL but it doesn't required to upgrade cucm version.
( i guess we cant use both licence type at the same time DLU and UCL).
(clarify me if my understanding is wrong)
Thanks.
VIP Purple
Hi Frank,
refer the link
regds,
aman
Thanks Aman.Its mean i can
Thanks Aman.
Its mean i can use both UCL and DLU at the same time (with v.8.6). if i upload LIC-CUCM-9X-USR-A it will work as DLU (at backend)?
and another thing as ex. for cp-7942
         with DLU license its required 4 DLU
         with UCL license its required 6 DLU (enhanced = 6DLU)
any idea on this?
i dont have access to the above thread link.
VIP Purple
Hi Fraank, you cannot use
Hi Fraank,
you cannot use this Part Code and check in Table 2
http://www.cisco.com/web/partners/downloads/partner/WWChannels/technology/ipc/downloads/UC_8_6_OG.pdf
for new purchases:
Start with Top Level part number R-CUCM-USR-LIC
LIC-CUCM-USR-A UCL - 1 Enhanced User, Tier A, 1-999 users
LIC-CUCM-USR-B UCL - 1 Enhanced User, Tier B, 1000-9999 users
LIC-CUCM-USR-C UCL - 1 Enhanced User, Tier C, 10,000 and greater users
LIC-CUCM-BASIC-A UCL - 1 Basic User, Tier A, 1-999 users
LIC-CUCM-BASIC-B UCL - 1 Basic User, Tier B, 1000-9999 users
LIC-CUCM-BASIC-C UCL - 1 Basic User, Tier C, 10,000 and greater users
LIC-CUCM-ESS-A UCL - 1 Essential, or an application user add-on
LIC-CUCM-ESS-B UCL - 1 Essential, or an application user add-on
LIC-CUCM-ESS-C UCL - 1 Essential, or an application user add-on
regds,
aman
thanks for the correct part
thanks for the correct part number.
Its mean i can use both UCL and DLU at the same time (with v.8.6). if i upload LIC-CUCM-USR-A it will work as DLU (at backend)?
can you pleas clarify on me above?
i need to purchase new UCL license soon also need to use existing DLUs without any conversion.
Thanks.
VIP Purple
Hi Frank, yes, u can mix them
Hi Frank,
yes, u can mix them. At backened, it is all DLU till CCM 8.
I won't be able to comment on consumption of DLUs in UCL.
We can wait if somebody expert on this part helps us else request u to open a new thread.
regds,
aman
Grate thanks Mr. Aman.your
your comment is really help-full. i will order LIC-CUCM-USR-A UCL
Thanks.
Hi,Just one more things to
Just one more things to clarify.
Currently we have (20 analog phones) VG224 + cp-6901
If i use DLU+UCL at same time how license allocated with these analog and 6901 phones?
With DLU - no license required.
With UCL - Essential required.
Thanks.
VIP Purple
Hi Frank,Just refer this
Hi Frank,
Just refer this discussion.In CUCM 8.x , no DLUs are consumed for analog/3905 IP phones.
Further, if u are purchasing licneses for Analog /6901/3905  , u need to have UCL Essential license.
regds,
aman
Hi Aman,I understood what you
Hi Aman,
I understood what you mentioned above. but in my case.
Currently im using DLU and i need to purchase UCL (because DLU is going to eos). and as you told, in cucm 8.6 UCL act as a DLU at the backend (when i mixed DLU and UCL in same server ). so can we add new analog phones without (UCL-essential).
If i use only UCL i know for analog phones its required UCL-essential.
Hope you will understand my situation.
VIP Purple
Hi Frank,
Analog Phone
CTI Port
0 -DLU's
regds,
aman
Thanks a lot Aman.everything
Thanks a lot Aman.
everything is clear
503
