DMA 7.0(2) warning SQL error executing "update DeviceNumPlanMap"
I have about 20 of these warnings, overall we have about 1500 phones/users on 4.1(3)SR6. Will it mean they won't export/import to CallManager 7.0(2)?
Row: 5738 SQL error: -746(35317)
Error executing "update DeviceNumPlanMap set fkDevice='39fca740-6ee4-4e16-9821-607410de3b90' where pkid='f70a5efb-347d-4699-84e8-fe060ce0ceb1'": [Informix][Informix ODBC Driver][Informix]Unspecified System Error = -746. sqlerrm(35317)
pkid f70a5efb-347d-4699-84e8-fe060ce0ceb1 NOT MODIFIABLE
fkDevice 39fca740-6ee4-4e16-9821-607410de3b90
NumPlanIndex 1
Label
fkNumPlan fb8d6d98-f8dd-4b85-9ac7-c8a7c7f4ab07
Display Efrain Soto (Ex-Marco Barcenas (Wireless))
tkRingSetting 0
CtiID 5738 NOT MODIFIABLE
E164Mask
DialPlanWizardGenID
tkMWLPolicy 0
tkRingSetting_Consecutive 0
MaxNumCalls 3
BusyTrigger 2
CallInfoDisplayMask 9
LabelASCII
DisplayASCII Efrain Soto (Ex-Marco Barcenas
tkRingSetting_ActivePickupAlert 0
tkRingSetting_IdlePickupAlert 0
tkPartitionUsage 99 NOT MODIFIABLE
SpeedDial
fkRecordingProfile
fkCallingSearchSpace_Monitoring
tkStatus_AudibleMWI 2
* End of warnings found during CallManager database validation.
* CallManager database validation.
* Date/Time : 03-05-09/11:07:46 PM
Re: DMA 7.0(2) warning SQL error executing "update DeviceNumPlan
Probably need to open a tac case. but do i read the log file correct the display name has odd characters in it like Ex-Marco )) () stuff like that I wonder if it's throwing it off.
It could be a warning you *could* ignore, but its a tough call. TAC will better be able to diagnose it. If you have a new server for 7.02, id probably see if it the DMA loads. If it loads, and the device/line all look correct, Id probably ignore it.
Would this DMA error occur if Display exceeds 30 characters?
I tracked down this 7920G phone, went to the line;
Line Settings for this Device >
Display (Internal Caller ID) >
Is that not a valid Display?
From help;
Leave this field blank to have the system display the extension.
Use a maximum of 30 alphanumeric characters. Typically, use the user name or the directory number (if using the directory number, the person receiving the call may not see the proper identity of the caller).
Setting applies only to the current device unless you check the check box at right and click the Propagate selected button. (The check box at right displays only if other devices share this directory number.)
214
