DMA 7.01a failure on CCM/IPCX
swaro2000
We currently have CCM 4.3(2)Pub & Sub. The Pub also has IP Contact Center Express version 4.1(1)b085 on the same box. We planning to upgrade to CCM
7.01 So I installed DMA 7.01a. DMA generates the following error...
[12:10:23 PM] Accessing database...
[12:18:34 PM] modExportDatabase=Failure
[12:18:34 PM] Failed to complete database processing successfully.
[12:18:34 PM] Failed to validate Cisco CallManager database and directory exported data.
[12:18:34 PM] The exported data cannot be used for upgrade.
[12:18:34 PM] Correct the database and/or directory data and run DMA again.
[12:18:34 PM] Verification of DB in IDS failed. Retaining the TAR file as it is.
[12:19:22 PM] The results are : Export - Successful. Validation - Failed.
How do we resolve this, so we can proceed with the CCM upgrade? BTW I got a similar error when I tried DMA 7.02. I suspect the error/failure may be from having IPCC on the Pub. Can we run DMA on the Sub since it fails on the pub?
abrenes26
did you resolve this issue?
I'm running through the same problem and I wish to know your situation related to this.
tensk8
