DMA CCM 4.0(2A) to 6.1(1A)
I want to do a DMA from CCM 4.0(2A) to 6.1(1A).
The version 6.1(1A) will be running on a brand new server.
I ran the CallManager Upgrade Assistant file CCMUpgdAsstInstall.4-3-13.exe. And everything was OK exept the memory.
My old server is MCS-7835i-3.0-IPC1 with only 1 Gig of memory and as per the Upgrade assistant I need 2 Gig.
Could I run the DMA anyway ? It took me 3 hours to install the DMA software, and normally as per the documentation it take 20-40 minutes.... Could I expect my DMA will only take more time and it's suppose ?
Somebody have already try that ?
10/15/2010 22:10:38.549 ResourceCheck.cpp ResourceChk ===============================================
10/15/2010 22:10:38.549 ResourceCheck.cpp ResourceChk ============ Resource Check Module ============
10/15/2010 22:10:38.549 ResourceCheck.cpp ResourceChk INFO: User input of minimum memory required (string): 2000 MB
10/15/2010 22:10:38.549 ResourceCheck.cpp ResourceChk INFO: User input of minimum memory required (int): 2000 MB
10/15/2010 22:10:38.549 ResourceCheck.cpp ResourceChk INFO: The minimum memory requirement is 2000 MB
10/15/2010 22:10:38.549 Utilities.cpp instGetPhyscialMem Total Physical memory: 1073102848
10/15/2010 22:10:38.549 ResourceCheck.cpp ResourceChk INFO: The installed physical memory is 1073102848 Bytes
10/15/2010 22:10:38.549 ResourceCheck.cpp ResourceChk INFO: The installed physical memory is 1023 MB
10/15/2010 22:10:38.565 ResourceCheck.cpp ResourceChk iuRegQueryValueEx: Function started
10/15/2010 22:10:38.565 ResourceCheck.cpp ResourceChk iuRegQueryValueEx: Function ended
10/15/2010 22:10:38.565 ResourceCheck.cpp ResourceChk Info: Server is a CCM Publisher
10/15/2010 22:10:38.565 ResourceCheck.cpp ResourceChk  ERR: The system does not meet the minimum memory requirement (expecting at least  "2000" MB, but found "1023" MB)
10/15/2010 22:10:38.565 ResourceCheck.cpp ResourceChk INFO: Resouce Check Module return code: -10
Louis
Re: DMA CCM 4.0(2A) to 6.1(1A)
You can run DMA as long as the new server meets the requirements to support the 6.1 version you will install. Check the compatibility guide below:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Tere.
Regards, Tere. If you find this post helpful, please rate! :)
     Just to be sure, my new server mets the requirements for running the CUCM 6.1(1a) but the old publisher server whois running CCM 4.0(2a) where I will run the DMA software have only 1 gig of memory. After run the DMA on that server I will install directly on the new server CUCM 6.1(1a) with the .tar file.
Did you already, did that kind of upgrade where the Call Manager Upgrade Assistant give you that memory error ?
I fear to do DMA and the server crash because we don't have enought memory.
193
