DMA DATABASE Error
I am getting the below errors in database when I am trying to run DMA to migrate/upgrade Call Manager from 4.2 to 7.1 any ideas :
[05:10:16 PM] Accessing database...
[06:21:15 PM] modExportDatabase=Failure
[06:21:15 PM] Failed to complete database processing successfully.
[06:21:15 PM] License file (licupgrade.lic)is not generated as expected due to unsuccessful initialization or DMA validation.
[06:21:15 PM] Failed to validate Cisco CallManager database and directory exported data.
[06:21:15 PM] The exported data cannot be used for upgrade.
[06:21:15 PM] Correct the database and/or directory data and run DMA again.
[06:21:15 PM] Verification of DB in IDS failed. Retaining the TAR file as it is.
***> DATA PROCESSING TESTS REVEALED AN ISSUE WHICH GENERATED THE FOLLOWING EVENT:
    Sorry.  Unable to parse and identify error number.  Raw Message follows:
    02/12/2012 17:38:43.191 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 7|
    02/12/2012 17:38:43.191 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 4|
    02/12/2012 17:38:43.534 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 7|
    02/12/2012 17:38:43.534 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 4|
    02/12/2012 17:38:43.800 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 7|
    02/12/2012 17:38:43.800 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 4|
    02/12/2012 17:38:45.175 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 7|
    02/12/2012 17:38:45.175 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 4|
    02/12/2012 17:38:46.644 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 7|
    02/12/2012 17:38:46.644 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 4|
    02/12/2012 17:38:46.894 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 7|
    02/12/2012 17:38:46.894 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 4|
    02/12/2012 17:38:47.081 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 7|
    02/12/2012 17:38:47.097 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 4|
    02/12/2012 17:38:48.394 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 7|
    02/12/2012 17:38:48.394 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 4|
    02/12/2012 17:38:48.847 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 7|
    02/12/2012 17:38:48.847 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 4|
    02/12/2012 17:38:49.644 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 7|
    02/12/2012 17:38:49.644 installdb|   CSV::ConvertFile *ERROR* Column/types/values size mismatch, Names 10, Types 10 Values 4|
    02/12/2012 17:39:29.754 installdb|   installFull *ERROR* Prior Cancel or Error Processing installCsv (c:\tmp\db\exported)|
*          End of errors found during CallManager database validation.
*          CallManager database validation.
*          Date/Time  : 02-12-12/06:21:15 PM
*          End of errors found during DMA Frame Work.
*          DMA Frame Work.
*          Date/Time  : 02-12-12/06:21:27 PM
End of Logs,Thanks
1 REPLY
Super Bronze
DMA DATABASE Error
There should be other log files, this is a summary only. The full log file that contains those 'installdb|  installFull *ERROR*' entries would be worth posting up so we can look at the contextual entries.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
314
