DMA erreur message (CCM4.2(3)srb4b---> CUCM7.1(5)
Can you help me de fix this DMA msg error.
Thanks in advance
Racim
DATA PROCESSING TESTS REVEALED AN ISSUE WHICH GENERATED THE FOLLOWING EVENT:
The error number is:  [-691]
The error message is:  [-691 Missing key in referenced table for referential constraint
The following additional event information is available:
  This record was not processed because another record it needs,
  (see reference name listed below), is missing.  This likely may be due to a previous error
  already reported in the log above, or the result of Directory Services Export issues
  reported separately, or due to missing Product, Locale, or other add-on definition CSV
  files that should exist on the source system but do not.
  SUGGESTED ACTION:  Resolve all prior reported issues.  If none, look at the Suspected Field,
  if listed, for an indication of what data reference could not be resolved.  Some hints:
   - if ...DirGroup related, check for a Directory Export failure
   - if ...Locale related, check for a missing Locale Plug-In
  Re-execute DMA when all other issues are addressed.
Suspected Field/Item Is [DMABack_Admin.tk_troubleshootingtrace_tkservice]
TABLE NAME IS [troubleshootingtrace ]
fkprocessnode             '6cee9db2-27fb-4c7d-9530-dfec38d30fe1'
  pkid                     '3a31b103-e0d6-4ab3-94a1-f7d3cf5e339e'
  tkservice                6
  tracelevel               1
  usercategories           1
  enable                   'T'
  numfiles                 250
  numlines                 10000
  numminutes               1440
  includenondevicetraces   'F'
  usexml                   'F'
  devicetypemonitorflag    'T'
  devicenamemonitorflag    'F'
  filetraceflag            'T'
  outputdebugstringflag    'F'
  maxfilesize               1000
Re: DMA erreur message (CCM4.2(3)srb4b---> CUCM7.1(5)
Did you run the Migration Utility to validate the database before you ran DMA?  It looks like you've got something slightly scrambled in there.  This is common if a customer enabled MLA, added users to groups, and then deleted the phones the users had previously been associated with.  That problem is very recognizable since any attempt to open any of the DMA groups affected will result in an error.
Re: DMA erreur message (CCM4.2(3)sr4b---> CUCM7.1(5)
Yes I did, curiously I ran a second DMA and I still have the previous error but the DMA status was : (The results are : Export - Successful. Validation - Successful with warning(s).)
Ok. You have something wrong in the database, and it's more than you can go through on a board posting. Get TAC involved to help you out. They have folks dedicated to this type issue.
Cliff
NOTICE OF CONFIDENTIALITY:
The information contained in this email transmission is confidential information which may contain information that is legally privileged and prohibited from disclosure under applicable law or by contractual agreement. The information is intended solely for the use of the individual or entity named above.
If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or taking of any action in reliance on the contents of this email transmission is strictly prohibited.
If you have received this email transmission in error, please notify us immediately by telephone to arrange for the return of the original transmission to us.
No errors atfer reseting trace configuration setting.
Regard,
Racim
383
