DMA Error 4 to 7
I am running the DMA tools, to upgramde CCM from the version 4.2(3) to 7.0 but I have the following errors:
[09:05:39 AM] Validating exported Cisco CallManager database and directory data.
[09:05:39 AM] This can take a long time, depending on the size of the database and directory. Be patient.
[09:05:39 AM] Estimated time to complete data validation is about 51 minutes.
[09:05:39 AM] Accessing database...
[09:09:47 AM] modExportDatabase=Failure
[09:09:47 AM] Failed to complete database processing successfully.
[09:09:47 AM] Failed to validate Cisco CallManager database and directory exported data.
[09:09:47 AM] The exported data cannot be used for upgrade.
[09:09:47 AM] Correct the database and/or directory data and run DMA again.
[09:09:47 AM] Verification of DB in IDS failed. Retaining the TAR file as it is.
[09:09:47 AM] Building archive C:\DMA TAR\DMAExportFailed08-21-10#9-02.tar.
[09:09:53 AM] Archive built successfully.
09:22:21 AM] The results are : Export - Successful. Validation - Failed.
[09:22:21 AM] ********************************************************************************
[09:22:21 AM] It is mandatory to refer to the Post-Upgrade Tasks section of the Upgrading Cisco Unified CallManager to understand and complete all the critical tasks after the upgrade.
[09:22:21 AM] See document at http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_installation_guides_list.html
How I can resolve this problem ?
Suggest?
Re: DMA Error 4 to 7
In the DMA Error I found this messages:
***> DATA PROCESSING TESTS REVEALED AN ISSUE WHICH GENERATED THE FOLLOWING EVENT:
Sorry. Unable to parse and identify error number. Raw Message follows:
08/21/2010 20:37:51.895 installdb| installFull *ERROR* Prior Cancel or Error Processing installSql (c:\tmp\db\sql\dbfuncs_win.sql)|
08/21/2010 20:37:52.504 installdb| installFull *ERROR* Prior Cancel or Error Processing installSql (c:\tmp\db\sql\makedb.sql)|
The error number is: [-329]
The error message is: [-329.
Sorry. Unable to parse and format record info from log message. Raw Message follows:
[08/21/2010 20:37:54.567 installdb| validateDB *ERROR* SQL Exception [0xfffffeb7] [Failed to connect to datasource: [Informix][Informix ODBC Driver][Informix]Unspecified System Error = -329.]|
any recommendations?
Is a good option, install DMA version 6, and install Cisco Call Manager version 6 and then install de CUCM version 7 ¿?
DMA Error 4 to 7
I'm experiencing same exact error.
Anyone has solved it?
Daniele
Re:DMA Error 4 to 7
It's saying failed to connect to the DB did you perform uninstall and the re install of the software I see you are running cucm 4.2.3 can you let us know the exact ccm version and OS version there was a dma issue that required you to be on a specific ccm OS release. Also have you turned off the Cisco security agent prior to running
Sent from Cisco Technical Support Android App
Re:DMA Error 4 to 7
might want to have a look at the following bug as well
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCte01723
you might have to uninstall DMA, upgrade your OS to the latest SR on 2000 4.6 and the reinstall the latest DMA.
see if it helps.
514
