DMA Errors on Call manager 4.2(3) to 7.1(3)
I run the DMA on a CM 4.2(3) that i want to upgrade at version 7.1(3). I get thiese errors:
***> DATA PROCESSING TESTS REVEALED AN ISSUE WHICH GENERATED THE FOLLOWING EVENT:        Sorry.  Unable to parse and identify error number.  Raw Message follows:      12/23/2009 17:40:52.614 installdb|   installFull *ERROR* Prior Cancel or Error Processing installSql (c:\tmp\db\sql\dbfuncs_win.sql)|
***> DATA PROCESSING TESTS REVEALED AN ISSUE WHICH GENERATED THE FOLLOWING EVENT:        Sorry.  Unable to parse and identify error number.  Raw Message follows:      12/23/2009 17:40:52.723 installdb|   installFull *ERROR* Prior Cancel or Error Processing installSql (c:\tmp\db\sql\makedb.sql)|
***> DATA PROCESSING TESTS REVEALED AN ISSUE WHICH GENERATED THE FOLLOWING EVENT:        The error number is:  [-329]      The error message is:  [-329     Database not found or no system permission. ]      Sorry.  Unable to parse and format record info from log message.  Raw Message follows:           [12/23/2009 17:40:52.957 installdb|   validateDB *ERROR* SQL Exception [0xfffffeb7] [Failed to connect to datasource: [Informix][Informix ODBC Driver][Informix]Unspecified System Error =  -329.]|  ]
Can some one help me?
Giovanni
Re: DMA Errors on Call manager 4.2(3) to 7.1(3)
Hi.
I have the same problem
can you resolve this?
TKS
Martin
Hi Martin,
yes I solved the issue , I done at the same time the reinstall of the DMA and tthen I run it disabling the antivirus.
Giovanni
I have the sames error messages, but I dont have installed antivirus.
08/21/2010 20:37:51.895 installdb| installFull *ERROR* Prior Cancel or Error Processing installSql (c:\tmp\db\sql\dbfuncs_win.sql)|
08/21/2010 20:37:52.504 installdb| installFull *ERROR* Prior Cancel or Error Processing installSql (c:\tmp\db\sql\makedb.sql)|
The error message is: [-329.
[08/21/2010 20:37:54.567 installdb| validateDB *ERROR* SQL Exception [0xfffffeb7] [Failed to connect to datasource: [Informix][Informix ODBC Driver][Informix]Unspecified System Error = -329.]|
Hi Ricardo,
sorry but I'm in vacation and read the mail sometime. I also reinstalled the DMA , have you  done that?
Giovanni
1018
