DMA Export during business hours
Hi all,
Has anyone run DMA export during business hours ? any issues or concerns with running DMA export during business hours ?
Thanks in advance for any inputs / suggestions !!!
D.
  • IP Telephony
1 REPLY
Re: DMA Export during business hours
Yes.  Two caveats I'd point out - both of which bare consideration:
1) When you install DMA, you have to reboot the Publisher.
2) When you run DMA, the CPU on the Publisher can be taxed.  As in, the process runs at high priority and can be service impacting.  I have seen it drop/restart services while running.
So, best practice is to run it during a planned change/outage window...just in case.  You should likely do the same.
Hailey
Please rate helpful posts!
151
